Benchmarking Info
10 Mar 2003
Hi,
I wondered if someone could give me some advice as to what program to use now for benchmarking.
I had problems getting 3DMark Vantage working (problem with a missing DLL even though the DLL wasn't missing).
I'd also like to know roughly what score I should be getting on the recommended program with the spec below:
Q6600 @ 2.4GHz
8GB PC6400 RAM @ Stock
ATI HD 4870 1GB RAM @ Stock
Resolution: 1920 x 1080
Thanks,
M.
Or try all of the 3d mark series for graphic tests, even though they are old people still run them to compare scores.
I know on 3d mark 06 it complained about a file with me but there is a known fix for it, think i had to delete or rename a certain file - google told me :D
