Benchmarking made more fun!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
True enthusiasts and bench markers need an open chassis for two reasons.
1. To make upgrading/changing hardware quick and easy.
2. To ensure cooling is maximised and not hot-spots are generated like with a closed chassis
So we have teamed with Dimas Tech to bring you the following products.
DimasTech Bench Table V2.5 Hard - Grey @ £69.95 inc VAT
Finally after a long absence from the market of our products by Bench Table by which we pioneered in 2007, returns to the square from the Bench/Test Table Hard in version V2.5.
This new product is born again after having collected a lot of feedback from the customers most experienced by the user and even "novice" who always helps us to improve our products. Below you will find the salient features of the new Bench/Test Table V2.5 Hard.
This product unlike the Easy version, has the strengths of the full functionality and ease of use, dedicated to the clocker who wants to have a location from Bench/Test easy to manage, with all the hardware in sight.
The "Bench/Test Table Hard V2.5" can be used both as a station for testing, both as a normal holiday, but also for expositions in which you want to show the viewer what components are being used and present the hardware more attractive than usual brothels.
The Bench/Test Table Hard V2.5 has also included a special support for the attachment of Pot (see category: Extreme Cooling Section Pot), with a bow and threaded rod, this system allows you to set a Pot or any sink without the use of clips or brackets, in any position on the motherboard.
To meet the need of rapid disassembly of the components from the Bench/Test Table Hard V2.5 has available new Thumbscrew, to fix any part of the feast itself or hardware. The "Bench/Test Table Hard V2.5" has the peculiarity of being mounted on the version Easy, just resting it and securing it with 4 pads, so you have a location from the Far Bench proper (Model Easy/Hard V2.5 can always find him in this section of the shop: Bench/Test Table EasyHard V2.5).
- Bench made from sheet metal 1,5 mm,
- CNC laser cutting
- Powder or Enamel, basic phosphatic
- Totally "Made in Italy"
- Compatible with ATX and Full ATX motherboard and Micro ATX, XL-ATX, Mini ATX
- Support for sockets with fan ventilation area 120x120,
- Support for ventilation area opposite the video card fan 120x120,
- New holes on the front motherboard to allow the passage of cables and pipes for watercooling,
- ABS plastic handles,
- Arch made with pickled sheet thickness 6mm,
- M6 threaded rod for locking Pot or sinks of various kinds,
- Special bolts that can slide on the track of the arc, and capable of blocking both the threaded rod bolt that the same arc, with a simple nut butterfly
- Scroll arc along the surface of the motherboard, for full compatibility with all motherboards in circulation and future
- Ability to use Pot up to 30 cm high
- Compatibility with the new Bench/Test Table Easy V2.5,
- Possibility of mounting "On Top" of the new Bench/Test Table Easy V2.5 without hindering the pipes of the cooling liquid
- Supported VGA cards and included additional
- Tool Free
Contents of Package:
- DimasTech Bench/Test Table Hard V2.5,
- N°1 Complete set of screws for hardware,
- Arch
- Auction with knurled knob
- 12 spacers for the motherboard,
- Two stickers DimasTech
Only £69.95 inc VAT.
ORDER NOW
DimasTech Bench Table V2.5 Hard - White @ £69.95 inc VAT
- CNC laser cutting
- Tool Free
- Arch
ORDER NOW
DimasTech Bench Table V2.5 Hard - Graphite Black @ £69.95 inc VAT
- CNC laser cutting
- Tool Free
- Arch
ORDER NOW
DimasTech Bench Table V2.5 EasyHard - White @ £169.99 inc VAT
Finally after a long absence from the market of our products by Bench Table by which we pioneered in 2007, returns to the square from the Bench/Test Table EasyHard in version V2.5.
This new product is born again after having collected a lot of feedback from the customers and even more experienced user "novice" who always helps us to improve our products. Below you will find the salient features of the new Bench/Test Table EasyHard V2.5.
This particular case and dedicated mainly to the user who is not content than normal houses, but he wants something more, that functionality that all users are addicted to the "frequent changes of constituents needs”.
The " Bench/Test Table EasyHard V2.5" can be used both as a station to test, whether as a regular holiday for everyday use, or for those expositions in which the viewer wants to understand what components are being used and present the hardware more attractive than usual brothels, which has little room to see the impassioned components used.
The Bench/Test Table Easy/Hard V2.5 offers more support and compatibility with products certified for liquid cooling, and all the hardware in circulation. Compared to the previous version are available a PSU support, and support for pump + tank (optional) native to the integration of liquid cooling.
The Bench/Test Table Easy/Hard V2.5 has also included a special support for the attachment of Pot (see category: Extreme Cooling Section Pot), with a bow and threaded rod, this system allows you to set a Pot, or any sink without the use of clips or brackets, in any position on the motherboard.
This new version offers the customer particular predisposition for all types of radiators on the market:
HwLab,
Thermochill,
TFC
Etc ...
To meet the need of rapid disassembly of the components from the Bench/Test Table Easy V2.5 has available new Thumbscrew, to fix any part of the banquet itself or hardware or support for expansion cards.
Section Bench/Test Table, category Accessories, you will find the complete list of accessories available in the catalogue.
- 455mm depth x 440mm width x 210mm height (height considering the pins and do not consider the spacers supporting motherboard, 25mm)
- Table made sheet of 1,5 mm,
- CNC Laser Cutting,
- Written "Made in Italy" on the back of the Bench/Test Table
- Installation of up to 3 devices 5.25 inches
- Installation of up to 3 hard drives (3.5 inch) 4 or more floppy disks with no floppy drive,
- Support for ventilation fan socket area 120x120,
- Support for ventilation area before the video card fan 120x120
- Brand new buttons wired for power and reset switches, (n ° 2)
- Holes on the front and back of the motherboard to allow the passage of cables and pipes for watercooling downstairs
- Support for feeders positioned on the front or back of the Bench/Test Table
- Compatible with power supplies up to 22cm in length,
- Support for lateral installation of all types of radiators on the market (HwLab, Thermochill, TFC, Etc)
- Rear space for installation of a compact liquid cooling system,
- Thumb Screws step M3 and 6-32 (American pitch UNC)
- Support for 120x120 mm fan for cooling systems in SLI/Crossfire
- Rubber feet Support Ram fan 120x120 mm
- Lower tray with sliding tracks and fixation with screws knurled side
- Placement supported devices on slots
- Personalization side of the body with the basic version of the Bench/Test Table
- Positioning devices adjustable supports
- Supports for adjustable radiator over the back of the Bench/Test Table
- Screws Knurled for nuts
- Total elimination of the use of instrumentation outside the Bench/Test Table
- Full compatible for mounting of earlier versions of media and Bench/Test Table Hard V1.0 and V2.0
- Full compatibility with the new Bench/Test Table Hard V2.5
- Prepared for 4 passes for watercooling pipes or fittings on the back of the motherboard
- Possibility assembly front USB port (DimasTech USB Cable is available as an accessory - see section Accessories)
- DimasTech Bench/Test Table Easy V2.5,
- 1 kit with screws for hardware,
- Arch
- 1 kit with screws for fixing thumb screws + card support for expansion
- Two adhesive DimasTech
Only £169.99 inc VAT.
ORDER NOW
DimasTech Bench Table V2.5 EasyHard - Grey @ £169.99 inc VAT
HwLab,
Thermochill,
TFC
Etc ...
- Arch
ORDER NOW
DimasTech Bench Table V2.5 EasyHard - Graphite Black @ £169.99 inc VAT
HwLab,
Thermochill,
TFC
Etc ...
- Arch
ORDER NOW
DimasTech Bench Table V2.5 Easy - White @ £99.98 inc VAT
Finally after a long absence from the market of our products by Bench Table by which we pioneered in 2007, returns to the square from the Bench/Test Table Easy version V2.5.
This new product is born again after having collected a lot of feedback from the customers most experienced by the user and even "novice" who always helps us to improve our products. Below you will find the salient features of the new Bench Table Easy V2.5.
This particular case and dedicated mainly to the user who is not content than normal houses, but he wants something more, that functionality that all users are addicted to the "frequent changes of components needs". In this new version V2.5, far more rich media and accessories, will not miss the usual customizations as DimasTech tradition.
The "Bench/Test Table V2.5 Easy" can be used both as a station to test, whether as a regular holiday for everyday use, or for those expositions in which you want to show the viewer what components are being used and present the hardware more attractive.
The Bench/Test Table Easy V2.5 offers more support and compatibility with products certified for liquid cooling, and all the hardware in circulation. Compared to the previous version are available a PSU support, and support for pump + tank (optional) native to the integration of liquid cooling.
HwLab,
Thermochill,
TFC
Etc ...
To meet the need of rapid disassembly of the components from the Bench/Test Table Easy V2.5 has available new ThumbScrew, to fix any part of the banquet itself or hardware or support for expansion cards.
The particularity of this project allowed us also to be able to integrate the "Bench/Test Table Hard V2.5" on this model, only by mounting it on top with the special assembly "On Top", in order to have a location from Bench Far proper (Model Easy/Hard V2.5 can always find him in this section of the shop: Bench/Test Table EasyHard V2.5).
- CNC laser cutting,
- Marked "Made in Italy" on the back of the Bench/Test Table
- Support for ventilation area opposite 120x120 video card fan
- Latest keys wired for power and reset switches, (n ° 2)
- PSU supports positioned on the front or back of the Bench/Test Table
- Compatibility with power supplies up to 22cm in length,
- Lateral support for the installation of all types of radiators on the market (HwLab, Thermochill, TFC, Etc)
- Rubber feet
- Ram fan support 120x120 mm
- Lower drawer with sliding tracks and fixation with screws knurled side
- Adjustable positioning device support
- Screws also knurled nuts
- Fully compatible for mounting versions of media and Bench/Test Table Hard V1.0 and V2.0
- DimasTech Bench/Test Table Easy V2.5, Support for hard disks and optical drives,
- Support ballast
- Support expansion cards,
- Fan support 120x120mm,
- Ram fan support 120x120mm,
- A complete kit of screws and fasteners for the thumb screws to support expansion cards,
- 10 spacers for the motherboard,
- 1 sticker DimasTech
- Installation Manual
Only £99.98 inc VAT.
ORDER NOW
DimasTech Bench Table V2.5 Easy - Graphite Black @ £99.98 inc VAT
HwLab,
Thermochill,
TFC
Etc ...
- Rubber feet
- Support ballast
ORDER NOW
DimasTech Bench Table V2.5 Easy - Grey @ £99.98 inc VAT
HwLab,
Thermochill,
TFC
Etc ...
- Rubber feet
- Support ballast
ORDER NOW
DimasTech Dust Cover - Grey @ £9.95 inc VAT
New and very practical DimasTech dust cover to protect your hardware from annoying dust that lurks in any space while the PC is to "rest"....
Useful for anywhere from Bench/Test Table DimasTech, compatible with any version of the Bench/Test Table DimasTech:
DimasTech Bench/Test Table DimasTechEasy and EasyHard V2.0
DimasTech Bench/Test Table DimasTechEasy and EasyHard V2.5
Note: Can be compatible with the Bench/Test Table DimasTech Hard V2.0 and V2.5 only if the arch is mounted
- Colour: Grey
- Synthetic nonflammable
- Logo Printed DimasTech
Only £9.95 inc VAT.
ORDER NOW
DimasTech Dust Cover - White @ £9.95 inc VAT
- Colour: White
Only £9.95 inc VAT.
ORDER NOW
DimasTech Power and Reset Switch Cable - 40cm @ £4.99 inc VAT
Couple of Cables with 2 pin connectors, power switch write on the connector (POWER SW) and reset switch write on the connector (RESET SW), 40cm length, Colored sleeving in Red and Black with
a tin terminal.
Only £4.99 inc VAT.
ORDER NOW
DimasTech Thumbscrew Kit 6-32 + M3 (40 Pack) - Silver @ £9.95 inc VAT
The DimasTech ThumbScrews M3 and 6-32 Thread made in Alluminium and than Anodized, the "easy to use" knob allows optimum clamping Devices.
The Kit includes Thumbscrews that have threads normaly used in all of Case (cabinet) on sell and a confortable Blister.
- Color: Silver
Contained of the Package:
- 20 ThumbScrews M3 Thread
- 20 ThumbScrews 6-32 Thread
Only £9.95 inc VAT.
ORDER NOW
DimasTech Thumbscrew Kit 6-32 + M3 (40 Pack) - Black @ £9.95 inc VAT
- Color: Black
Only £9.95 inc VAT.
ORDER NOW
DimasTech Thumbscrew Kit 6-32 + M3 (40 Pack) - Blue @ £9.95 inc VAT
- Color: Blue
Only £9.95 inc VAT.
ORDER NOW
DimasTech Thumbscrew Kit 6-32 + M3 (40 Pack) - Green @ £9.95 inc VAT
- Color: Green
Only £9.95 inc VAT.
ORDER NOW
DimasTech Thumbscrew Kit 6-32 + M3 (40 Pack) - Electric Purple @ £9.95 inc VAT
- Color: Electric Purple
Only £9.95 inc VAT.
ORDER NOW
DimasTech USB Port for BenchTable @ £4.99 inc VAT
Very practical USB DimasTech Cable applicable with two simple screws.
- USB Cable Length 25 cm
Package:
- USB
- 2 screws M3
Only £4.99 inc VAT.
ORDER NOW
I have the easyhard v2.5. I couldn't find a case that i liked so i said i'd try one of these for a change. I used it for about a month before going back to a case.
Too many niggles with it. Looks great at first but it scratches up bad very easily. Dust as expected is a big problem too. Dust cover aint much use while you're using your rig. What really bugged me though was that the motherboard standoffs would not screw in straight! and i actually snapped a couple trying to straighten them :mad:
Test benches are for losers, old cardboard box FTW :p
Nice to see the humble butterfly nut putting in an appearance :D The cheapest one looks intereting but not sure where the psu or hdd are meant to go?
