I have just tried running 3Dmark06 and it only says display device 1 of 1 however i am running 2 8800GTX BFG watercooled and overclocked. I have checked on GPU-Z and this shows the 2 GPU's could anyone tell me what i need to do to get this program showing both cards for benching, thanks.
. set up the sli bar(the green osd) so it runs while 3dmark runs. you will definitely know then.
