- 4 Sep 2016
Right I seem to be getting bad benchmarks and when I try to overclock then the system crashes using MSI afterburner to clock the GPU the cpu is clocked at 4600 via bios and seems stable and I get great temperatures as the whole system is water-cooled and has two radiators and five fans. My Heaven 4.0 benchmark is 1788 and I have seen people get high 4k so what am I doing wrong please? this mark is not gpu overclocked only cpu as the system freezes when I try to clock the gpu.
Bare in mind I have had a 20 odd year pc hiatus and have only built this in the last six months and only just trying to oclock. So I am no pc genius very much the opposite.
Thanks in advance
Ok here is my hardware set up first I have copied and pasted it from my Overclockers order so it may be info heavy lol.
Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - OEM
Asus Z170 Pro Gaming Intel Z170 (Socket 1151) DDR4 ATX Motherboard
Kingston Fury Black 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit - Black (HX424C15FB2K2/1
Super Flower Leadex GOLD 850W Fully Modular "80 Plus Gold" Power Supply - Black
Samsung 1.0TB 850 EVO SSD 2.5" SATA 6Gbps 32 Layer 3D V-NAND Solid State Drive (MZ-75E1T0B/EU)
Samsung 950 Pro 256GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive
XSPC EX360 120mm Radiator - Black
XSPC EX240 120mm Radiator - Black
XSPC D5 Tank Reservoir (V3)
XSPC D5 Vario (Body + Screwring)
EK Water Blocks EK-Supremacy EVO - Nickel
EK Water Blocks EK-FC1080/1070 GTX TF6 – Nickel + Plexi
EK Water Blocks EK-FC1080/1070 GTX TF6 Backplate - Nickel
EK Water Blocks EK-ACF Fitting 12/16mm - Black
EK Water Blocks EK-AF Angled 45 Degrees G1 / 4 inch - Black
Akasa AK-FN058 Apache Black Super Silent 120mm Fan - 4 Pin PWM
Mayhems Pastel - Ice White Coolant 1L
LG WH14NS40 Blu-ray Writer Optical Drive 14X BDR
Nvidia Titan X Pascal 12gb
Thanks in advance
