May be a bit of a silly question, but i've been mainly using Acrylic tubes, so have a bit of experience bending these.. however for those which are using metal tubes. e.g.
What tools do you use to bend these? I assume its not just brute force.. and i assume just a regular hacksaw is enough to cut them. How about RFP bits to chamfer or no?
I've only really seen people with pre-bent tubes and not any which multiple bends (usually using angled fittings to make secondary/tertiary bends). I take it this is uncommon
Brass hard tube 14mm AD 220x300mm 90 degrees - Pack of 4 - Silver
