Benefit of changing memory
29 May 2012
Dorset
Hi 8 pack I'm after some advice
When I built my pc up last year I filled my memory banks up as much as I could as cheaply as I could which at the time was 32gbs of these
http://www.overclockers.co.uk/showproduct.php?prodid=MY-349-CS&groupid=701&catid=8&subcat=1517
Now I have made use of them by setting up a ram drive for my temporary files and cache stuff which has helped speed some things up even over just running my ssd (10K read and write times on a drive are awesome) however I'm wondering if I could do better.
Most the time my pc is used for gaming which from what ive read really only needs 8gb now assuming that I kept a few gb of my ram drive 16gb tops is all I need, on that basis would I benefit much from getting better memory that could be tuned well over the current dominators, after all you did say yourself the doms arnt really that clockable and even if I push extra volts through them Im probably not going to get much more out of them.
Lastly if I was to change what would you recommend? I quite like the look of these
http://www.overclockers.co.uk/showproduct.php?prodid=MY-041-TG&groupid=701&catid=8&subcat=1387
But is it money well spent?
Cheers
