Following on from the calibration thread, I've a few quesitons. Actually, I lie, I'm going to waffle for a bit, and someone can correct me.
I currently have my camera set to sRGB. Does this mean that every picture I take when printed on a printer with the same profile will match the colours correctly? If so, I'm assuming that if I have my monitor set on sRGB as well, then the colours will match properly between what I see on the monitor and what the camera recorded. Therefore, is there any reason to set my monitor to anything other than sRGB? Why do monitor manufacturers produce their own monitor profiles?
At a guess, if I have my monitor set to my_special_profile, then an sRGB image will look different until it is converted to use the same profile as my monitor. But, then no-one else will see it as the same colours on, say, the web, because they're all using a different profile? Is the best option to set the monitor to sRGB and be done with it?
Finally, when i go to print my photo, I should convert my photo to the colourspace used by the printer. That will, I assume, show me the colours that the printer will print it as, translated into whatever profile my screen is using? Does that mean I save two files, one adjusted for web display and one for printing?
Apologies for this, I've read a few articles and never quite got this one figure it out. If someone could explain using short words, that would be fab.
Thanks
Thanks
