I'm looking for the right cable to get 120hz mode on this monitor it's been said I need a dvi dual link cable I've looked on the Internet but I don't know what they look like. Could someone supply me a link please or picture.
Assuming its one of the BenQ XL24xxx monitors it should have a DL-DVI cable in the box as mentioned above, you can also use the displayport connection for 120Hz but I find DVI more reliable.
The ones which look like all the pin areas are filled up. Looked at a few differenti n the local cable shop and some have the square bits missing and won't do what you need. The fully pinned male male ones you need.
I have that cable. When i try to run in 120hz it gives me the error "please use correct cable supplied"
it is a 25 pin i believe with unplugging it i cant link to site i got it from as its a competitor but im sure its dvi-d
