BENQ 21.5" LED MONITOR ONLY £129.99
17 Oct 2002
Stoke
Got another BenQ LED deal for you on their 22" which offers fantastic value for money like it's bigger brother.
BenQ G2222HDL 21.5" Widescreen LED Monitor @ £129.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2222HDL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 504.6mm x 392.9mm x 175.0mm
- Weight: 3.8kg
- Warranty: 3 Years On-Site
Only £129.99 inc VAT.
ORDER NOW
I've got 2 and they are really nice monitors but compared to my dell they do take 30secs-1min to fully warm up so the colours look a little dull at first.
Might buy one. But because of the crap car on the front. I wont.
I agree. Tis much better now.
No HDCP right? Looking for a PS3 monitor :(
These do support HDCP.
is this monitor support HD and 3D gaming ?
is this monitor had it own speaker sound ?
They will support HD. You will need a HDMI to DVI cable if you're using it with an Xbox 360 or PS3.
Unfortunately it will not support 3D Gaming as you would need to spend twice as much!
The monitor doesn't have speakers built-in but to be honest you'd be far better spending another £5 on some Logitech S-120/S-150.
