I've just tried calibrating my new BenQ with my SpiderExpress4 and I'm a little confused.
With my old Dell 2408wfp I would choose Wide Gamut and the Spyder would calibrate fine (I only just discovered on checking however that the Dell is only 16.7m colours so I assume that's not Wide Gamut anyway, which is doubly confusing as the Spyder doesn't reject the setting).
With the BenQ which is specced as 1.07b colours the Spyder tells me halfway through that the display is not Wide Gamut and allows me to continue.
I think I'm confused about
1) What wide gamut means, because I thought it was the 1.07b panel type (the BenQ).
2) What is the best preset to use before calibrating? sRGB or User?
I do a lot of photo processing so having good accuracy and colour range is more important than gaming performance.
