Benq Ex2510 or 2710 for the Xbox Series X
26 Aug 2009
Okay I had a freak accident with my Asus Ve278H where I picked up a glass with wet hands and it slipped out of my hand and smashed my screen.
I bought the monitor in 2016 and I was mulling over the option of getting a new one anyway, but hey if it's not broken, don't fix it.
So I can't game on a large screen as I tend to overcompensate. I sit at a desk leaning forward when I play games such as Warzone and Red Dead online.
So my question is, I've heard the EX2510 is a better monitor with high pixel density and brightness.
But is it worth sacrificing size for the pixel density by getting ex EX2710?
Also, would it be worth spending up to £400 to get an even better monitor although I've not looked at any other monitors as I've heard nothing but good things about the Benq monitors?
Also, would I see much improvement on my Xbox and PC over the Asus ?
Thanks in advance.
All I would say is make sure whatever you get works properly with the series X. I bought an LG 27GL850, but it would not negotiate 120Hz at full res (only 60Hz) even though it’s spec’d to 144Hz. There should be plenty of posts out there by now from people saying what actually works well with series X.
I have a Dell 2721DGF 1440p and an EX2710. I much prefer the Dell on the Series X due to 1440p 120hz but switched to the EX2710 as I also have a PS5 which doesn't output 1440p.
The EX2710 is a good monitor but if you're only using a Series X I'd go with a 1440p if budget permits.
