- 28 Aug 2005
Want to use this monitor in a dual monitor setup but can't find one measurement I need from the spec sheet. Can someone with this screen do me a massive favour please...
I need the height of the underside of the screen from the desk when the monitor is in its lowest position. Needs to be in mm if possible, though no doubt the next ten posts will be arguing the figure to the nearest .01 of a mm!
Guessing the easiest way will be a piece of paper and a ruler as I don’t know anyone that keeps a tape measure on their desk apart from me.
Thanks
Thanks
