BENQ G2420HDBL 24" LED MONITOR ARRIVING TOMORROW
17 Oct 2002
Stoke
Finally had some stock of everyone's favourite monitor coming in tomorrow. :)
BenQ G2420HDBL 24" Widescreen LED Monitor @ £164.99 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
- Warranty: 3 Years On-Site
Only £164.99 inc VAT.
ORDER NOW
Could anyone suggest an alternative monitor? I REALLY like the look of this one and nearly bought it but I would like an HDMI port like the Samsung one here has.
i 2nd whitecrook, shudnt be a problem using a dvi hdmi adaptor. im not too fussed, DVI is good enough for me :-)
Well I was mulling some others and could not decide so went on the reviews. Ordered. Looking forwards to this my current monitor is a 19' 1280 x 1024!
Sorry for self quote but are these going to be shipped today? I just need to make sure there is somebody at mine to sign for it. :)
i bought this monitor for £148 not that long ago...still got the receipt and everything! (February 16th 2010) from ocuk off course :)
Isn't the only difference between DVI and HDMI is that the latter can carry sound. Otherwise the picture quailty is the same?
Bought this monitor myself, very happy with it. Though not had much use out of it yet as my PC is in bits rite now :(
