BenQ G2420HDBL Input Switching?
18 Jan 2011
Just ordered an Xbox 360 and I'm planning on using it with my BenQ G2420HDBL, I have my pc connected through DVI and want to use my Xbox via the microsoft VGA AV cable.
This monitor doesnt come with a remote, basically I want to know if I can have my PC on via DVI and my Xbox via VGA at the same time and switch input between or will the monitor just auto connect to w/e is switched on.
Any help or clarification will be appreciated.
Yes you can switch between DVi and D-Sub with the "Enter" button at the bottom.
But I have my Xbox 360 and PC both connected to the DVI on the monitor via a HDMI hub and a HDMI to DVI converter.
Thanks for the clarification :) I was wondering the same thing
also, i like the sig. very true.
