- 11 Dec 2005
- Cheshire
Benq XL2410T 24" TRUE 120Hz 3D Widescreen LED Monitor - Black @ £319.99 inc VAT
BenQ, proudly announced the release of their 23.6” (16:9 Aspect Ratio) LED Gaming Monitor XL2410T. BenQ understands that to lead and become a true and professional gaming monitor provider, they have to understand the mindset and needs of gamers. In order to achieve this goal, BenQ co-worked with ZOWIE, a professional Gaming gear manufacturer. BenQ have ZOWIE’s gamer teams join in during the product development and testing stages. With their assistance, XL2410T can truly be a professional LED gaming monitor – with a set of Gaming Display Modes which includes the FPS mode (First Person Shooting), co-developed by two legendary Counter-Strike players – Emil “HeatoN” Christensen and Abdisamad “SpawN” Mohamed.
Every serious gamer know that lag will cause you to lose a game; XL2410T is made to have a quick response to action, hardware lag will no longer be the cause for your headshots. XL2410T has a fast refresh rate of 120Hz for higher precision; a low input lag so the shots made is more in sync with the visual on-screen; a quick 2ms GTG (OverDrive) meaning users can see the edge of the enemies clearly and without motion blur, and Dynamic Contrast Ratio of 10,000,000:1 for detailed images and clarity in both darkened and brightened situations, this complemented with BenQ’s gaming tuning technology becomes a huge advantage for gamers.
XL2410T has a smart design, for one purpose – to win. The monitor has two hotkeys available; the first changes the display mode: Full; Aspect; Overscan; 1:1; 17”; 19”; 19” Widescreen and 22” Widescreen. Whereas the second hotkey is Smart Scaling, which lets the users adjust picture size in original input to the screen’s limit. Together with Display Mode function, users can play in the resolution size they are used to with their previous monitor, or adjust their screen size to what their teammates are using for easier communication and reference. From BenQ’s Gaming Display Modes options, users can choose from FPS Mode, made possible by co-working with the gaming heroes -HeatoN and Spawn as the best setting for personal shooting games, or from the two User Game modes for more dedicated and personalized settings.
For extreme entertainment, XL2410T is the LED monitor to go for. 3D-ready (NVIDIA 3D Vision certified); Picture by Picture (PBP); connectivity values (D-sub; DVI-D-DL, HDMI) and height adjustment feature are offered for users’ enjoyment and comfort. Picture by picture (PBP) is a feature that enables users to show two programs side-by-side on the screen. Feel like camping once in a while for fun? Watch a movie while you do it!
- LED Backlit
- Screen Size: 23.6" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 10000000:1
- Brightness: 300cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 6.0kg
- Height adjustable stand / Swivel 45/45 left/right
- Warranty: 2 Years On-Site
Only £319.99 inc VAT.
ORDER NOW
- LED Backlit
- VESA Compliant
- Weight: 6.0kg
ORDER NOW
