BenQ XL2411Z Monitor HDMI Artifacts
20 Jan 2018
Hello,
Hopefully someone may be able to help. I haven't used the HDMI input on the monitor in a while as I usually use DVI on PC to get 144hz, I recently purchased an Xbox One X console, however on HDMI the top right of the display appears to have weird square shapes and lines which are visible on light backgrounds all the time. I am using the HDMI cable supplied with the Xbox, I tried a different HDMI cable, the issue was still present. I tried the same HDMI cables on a different monitor (my old monitor ,BenQ XL2420T) and it displayed fine, both at 1080p. I've tried resetting my monitor settings to factory defaults however I feel like it may be a HDMI port issue. Has anyone seen anything similar to this before? Any help will be appreciated.
Regards,
