** BENQ XL2420T 3D VISION 2 LED MONITOR ARRIVES & £100 OFF DELL U2410 PRO MONITOR! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Two amazing deals here, first of all the Benq XL2420T is now in stock, this monitor is simply awsome value for money, more connections, better specification than previous and looks amazing. Then for those who want a professional IPS monitor I've reduced the pricing of our U2410 to make it the cheapest in the UK at over £100 off the previous sell price:-
Benq XL2420T 24" TRUE 120Hz 3D Vision 2 Widescreen LED Monitor - Black/Red @ £281.99 inc VAT
The XL2420T demonstrates BenQ’s true belief that "gaming is in the details" It has been co-developed with Counter-Strike pro gaming legends to bring you a gaming monitor like no other – from the attentive designs to the exceptional functions. With the precision and speed you would expect from a high-performance gaming monitor, you can now have a vantage point over your opponents in all your game play.
The task of conceptualizing the XL2420T as the ultimate gaming monitor involved a unique collaboration with prominent pro gamers: Tommy “Potti” Ingemarsson, Emil “HeatoN” Christensen, Abdisamad “SpawN” Mohamed, Michael “ahl” Korduner and Christer “fisker” Eriksson. These five names alone are synonymous when it comes to legendary Counter-Strike players. Their accumulated wealth of knowledge and skills helped BenQ develop a monitor that adapts to the needs of gamers to improve their chances of winning.
Poor visibility in dark scenes can cost even the most skillful gamers their game. The Black eQualizer color engine technology is designed to offer an unprecedented level of control and visibility. Dark scenes are brightened without over-exposing the bright areas to preserve vital details, enabling gamers to spot their enemies easily in critical combat and react quickly in any situation.
The XL2420T comes with a stylish S Switch. This distinct remote controller comes with three preset buttons so you’re able to customize and save your display settings for gaming, work or entertainment purposes. Use the scroll button on the S Switch to quickly navigate and change the OSD settings. It eliminates the tedious process of adjusting your monitor settings. Now switching seamlessly between the presets is as easy as 1-2-3.
The Display Mode and Smart Scaling features allow you to change the monitor view to suit your liking and to simulate any in-game experience. Interchange instantly between different screen sizes, from 17" (4:3), 19" (4:3), 19"W (16:9), 21.5"W (16:9), 22"W (16:10), 23"W (16:9) to 24"W (16:9), using the Display Mode. Or take advantage of the Smart Scaling feature and enjoy the flexibility to freely scale the screen content to any custom size. You can certainly use the two features together to get the best possible view for any application or game.
The preset FPS mode tailored by HeatoN and SpawN gives you the optimal brightness, contrast, sharpness and color tint in FPS games so you can spot your opponents and track their every move, even in indistinct situations. There are two variations to this special mode this year: the FPS1 mode is designed for Counter-Strike 1.6 and the FPS2 mode for Counter-Strike Source. The perfect combination of form and function provides gamers with the vantage point to always be one step ahead of the game.
With a refresh rate of 120Hz, there’s never a lag and every in-game details will be smoothly rendered. Drawing on hyper-speed video processing technology, the XL2420T gives you on-screen action and captivating realism.
Fast response time of 2ms GTG means speed without the smear for an enhanced gaming experience. Fast-moving action and dramatic transitions will be rendered smoothly without the annoying effects of smearing or ghosting. Control your gaming destiny and don’t leave it in the hands of slow display.
The newly designed OSD enables you to conveniently change your settings in an intuitive horizontal slide out menu display. This simplistic design makes it easier to navigate between options and settings.
The secret is out. Download special gaming presets used by HeatoN and SpawN so you can see what the pros see. Each mode is fine tuned so you can leverage these exclusive presets used by pro gamers to your own advantage. Users can install these exclusive presets and leverage them to their advantage. More presets from legendary gamers will be released in the future so you can always stay on top of your game.
The Height Adjustment Stand can be operated with just one finger so you can effortlessly adjust the height of the monitor to suit your sight level. Have the monitor way up high, or change it to sit flat on the table. The monitor can also be turned vertically or horizontally and comes with a quick-release VESA mount design. In addition, the sleek headphones hook at the back keeps your desk top neat and tidy.
Certified as NVIDIA® 3D Vision™ 2-ready with the new NVIDIA 3D LightBoost™ technology so you can experience gaming and entertainment like never before with total realism and intensive graphic display. Furthermore, the XL2420T supports D-Sub, HDMI, DVI-DL and DP inputs for console gaming action.
Features:-
- Product Color: Black-Red
- Screen Size: 24"W LED-backlight
- Resolution (max.): 1920 x 1080
- Pixel Pitch: 0.276 mm
- Brightness: 350 cd/m²
- Contrast Ratio: 1,000:1 / DCR:12,000,000:1
- Response Time: 2 ms GtG
- Viewing Angle (L/R;U/D) (CR>=10): 170 / 160
- Display Color: 16.7 million
- Color Gamut: 72%
- Terminals: D-sub / DVI-DL (Dual Link) / HDMI x 2 / DP 1.2 / Headphone Jack
- USB Hub: Donwstream x3; Upstream x1
- Color Temperature: Reddish / Normal / Bluish / User mode
- Features: Black eQualizer, Smart Scaling, FPS Mode, RTS Mode, Game Mode Loader, NVIDIA® 3D Vision™ 2 ready, Senseye 3, AMA
- HDCP
- K-Locker mount
- Height adjustment: 130mm
- Tilt (down / up): -5 / 20
- Swivel (left / right): -45 / 45
- Pivot: 90°
- 571.4 x 516.9 x 149.9 mm
- Gross weight: 6.1 kg
- VESA Wall Mounting (mm): 100 x 100 mm <
- 2yr On-Site Warranty
Only £281.99 inc VAT.
ORDER NOW
Dell UltraSharp U2410 24" Widescreen LCD Monitor - Midnight Grey @ £353.99 inc VAT
Experience astounding colour accuracy, precision and performance with the Dell UltraSharp U2410 Monitor. The U2410 is packed with features that make it easy to connect and a pleasure to use, no matter how much screen time you log including Picture-in-Picture, adjustable stand, touch controls and extensive connectivity. Thanks to PremierColor technology, the U2410 Monitor delivers reliable, true-to-life colour without the need for extensive calibration. 12-bit internal processing enables 1.07 billon colours and helps distinguish very low grayscale tones to deliver greater level of details in dark areas. A colour gamut of 110% delivers vibrant, true-to life colour across all display modes.
- Screen Size: 24" IPS Widescreen
- Resolution: 1920x1200
- Contrast Ratio: 80000:1
- Brightness: 400cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Component, 1x Composite, 1x VGA, 1x DisplayPort, 2x DVI-D & 1x HDMI
- Adjustable Stand
- VESA Compliant
- Dimensions: 559.7mm x 493.0mm x 201.5mm
- Warranty: 3 Years On-Site (Dell Premium Guarantee - You will receive a replacement UltraSharp monitor should even one bright defective pixel appear on the screen)
Was [£449.99] Inc. VAT
Only £353.99 inc VAT.
ORDER NOW
It is indeed VAT on shipping costs. - I have the first model of this monitor, and this is very tempting! I swear my wages just get spent on hardware!
Too expensive unfortunately. I have been waiting to get this monitor untill today and my eyes lit up when I saw you guys had it in stock just as I was about to buy it elswere, but the price with shipping included is way over the odds and too expensive... so sadly had to go elsewhere.
I have been looking for a new monitor that is 120Hz that looks good has everything I want
at a reasonable price and now I have found it, Will be getting this very soon.
So glad that I waited on getting a new monitor now.
Sigh, really want one!
My Dell 23" has been a great upgrade from my 16:10 1680x1050 HP screen but part of me feels I should have gone for a 120Hz or another 16:10 screen. It does the job, but isn't quite what I want!
SEE this is the problem when computer hardware is a hobby, and seeing these deals on OcUK! :o:D
