Benq XL2420T - 3D Vision help
30 Jun 2012
Village of Hessle, Hull
Hi, I've made a thread in the monitors section however I've had no success. This is the most viewed and replied to section so I thought I'd give it a go. I've just setup my new monitor the BenQ XL2420T. So far everything has worked great, however when I go to stereoscopic 3D Vision in nvidia control panel and run the setup there is no option for my setup. I recieved the monitor as part of an OCUK bundle with 3D Vision 2.0 kit as well. I was surprised when there was no IR Emitter with the kit. I googled this and I think the monitor has built in IR? Although this leads onto the setup issue. The only options are: Discovery 3D, Wired Glasses, USB IR Emitter and Glasses, Pro Hub and Glasses. I've tried all options 1st option doesnt work as I don't have that type of glasses. 2nd Option doesnt work as 1. I have wireless glasses. 2. It says Nvidia 3D Vision controller isn't installed when I know it is after reinstalling drivers multiple times within the past hours. 3rd Option doesnt work as I didn't recieve a IR Emitter and the 4th option doesn't work either as I don't have a 'Pro Hub'. I need help!
Just double checked. The monitor doesn't have a built in emitter, OCUK only sent me the glasses in the bundle without the emitter. Will be contacting them tomorrow, Not happy :@
I've got this monitor too. The XL2420T doesn't have an IR emitter built in, only the TX does.
If you've got the bundle and it had the 3D glasses kit, (rather than just the glasses on their own), there should've been an emitter included. Once this has been installed, you would choose the 'USB IR Emitter and Glasses' option.
