- 13 Jun 2011
Hi all
i have the above monitor and am hoping to be able to try 3d i know its nvidia 3d certified but can AMD HD3D work?
current specs are benq xl2420t
http://www.overclockers.co.uk/showproduct.php?prodid=MO-051-BQ
gigabyte 7970 windforce 3x
http://www.overclockers.co.uk/showproduct.php?prodid=GX-097-GI&groupid=701&catid=56&subcat=938
have done some googling and cant seem to find a definative answer. some are saying it cant be done but others are saying that it can by using the display port [amd hd seems to only work thru dp whereas nvidia works thru dvi-d]
my card has 2 mini dp outs.
main reason for asking is ive ordered myself a 3d vision 2 kit thinking it would be an easy plug and play wondering weither i need to send it back.
