Use a soft microfibre or optical cleaning cloth and any cleaning solution rated highly on various websites. Make sure the monitor is switched off and the screen surface is cool and only tackle small sections at a time. Some people recommend only cleaning in one direction (horizontal strokes) and others a circular motion but I wouldn't worry too much if you are patient, persistent and do the above.
