Bent component on Lamptron FC6 Fan Controller
16 Dec 2010
Just got my order today bang on 10am. I started unboxing everything including the fan controller. When I took it out of it's packaging I noticed these "things" were all bent. Should I just install the fan controller anyway and see if it still works? I don't know what I should do at the moment.
I installed it and everything is working fine. The only problem is I don't know how to change the colour of the LED display. Anyone have any idea?
E: The fan controller is the Lamptron FC6
My FC5 LED colours are configurable by way of re-arranging three sets of jumpers. I suspect a similar method is used for the FC6.
Did you not get any instructions with the controller?
Looks like 3 jumper headers at the bottom of the image in OP.
R G B.
Different combinations of jumpers on and off will give different colours.
I wonder if adding a variable resistor would actually give millions of colour options.
