Skip to the end if you don't fancy reading. I have a habit of explaining myself in long sentences.
Well yesterday before I started work I ordered my case for the hardware that has been sitting in my room for 4 days. So, well, 2 hours ago I came home from work rather happy that my case will be here on Tuesday and I couldn't help but be tempted to take out the items from their cases and connect them to my Mobo ready to just slide into my ATCS 840 case when it comes. I would then only have to connect my GPU, PSU and the cables after.
Well, I set my RAM onto the Mobo easily and proceeded to open the casing for my CPU and connect this too. I connected my AMD Phenom onto my Mobo fine, following the instructions on the provided leaflet (Instruction two for AM3 Mobos). I lined up the arrow on the CPU with the arrow on the Mobo like it shows in the instructions (I did also do the lever too like you are supposed to). The CPU placed perfectly and I slid the lever over to its original position.
Now, this is where it went wrong. I added the provided heatsink onto the Mobo above the CPU area and attempted to latch it onto Mobo like it shows in the leaflet. I did this on one side, but it would not connect on the other side. I thought I'd remove it and try again, but this is when I realised that the CPU is now stuck onto the heatsink! I thought at first it was like magnet (Yeah, sounds silly now that I think of it... A magnet used with sensitive hardware. There's a reason why we prevent static) This is when I saw that the CPU now had two bent pins on the outside, with both pins bent in the same direction.
I am presuming this damage was caused by me when I removed the heatsink (I guess I would have had to undo the lever if I were to remove the heatsink again :S? I don't see how though) One problem I am facing is if it was already like this before I placed the CPU. I did not actually check the pins beforehand and I handled the CPU in a soft manner. It was like a small, fragile new born baby to me.
I don't really know what to do... I just removed the CPU and cleaned the thermal compound from the CPU and heatsink and placed every single back into the boxes. I'm going to wait until my case comes... Forget the mise en place.
Well I am putting this here because I need help. Is this accident in my warranty at all? I followed the instructions. It's possible the pins may have been bent beforehand. The pins are like this:
Surely if I bent them removing the heatsink all the pins on that side would be bent? Especially the ones in the corner. I can't believe I have spent an hour sat here thinking about what to do.
So, yeah, will I have to buy a new CPU to arrive with my case or am under warranty still?
Edit: Taken out the box again to show a picture of what it is like. Sorry about quality... Take on iPhone.
They are bent flat in the same direction. I think they may have been bent beforehand and I just bent them flat when I placed the CPU down... Either way it is would be my fault.
Small world.
