Bent pins lga 1151
Hi,
Anyone know where i can get bent and broken pins on my motherboard fixed it has intel socket lga 1151
Thanks
Bent pins are one thing, but broken pins is most probably a whole new socket. That is not cheap and requires the most specialist equipment to complete and even though I’ve never had that done, I’d suggest the cost would be very high. Basically, unless you’re using the very top end motherboard (Asus maximus/apex etc), then it sounds like you’ll be needing to buy a new one.
