bent usb 3.0 pins
some of the pins have more than one bend... I am thinking about getting a new mobo because this one is a pain, so should i just wait?
Bend them until they are roughly straight then put a header on them, slowly and very carefully but firmly, that will bend them until they are usable again.
i have used my usb3 0 times to date. i would not replace the motherboard just because it this
this mobo has a bad problem where it will refuse to boot to windows and restart plus i dont have an io sheald (i know i dont need it but is scares me when pluging stuff in and its on that i will short it out). the mobo was a great starter in to x99 but might as well get some thing with a warranty. in all fairness i did buy a grade b mobo. i will try bending them back xD thanks
