- 30 Mar 2017
Recently replaced the water cooling loop on the Build from Scan (going 2 years strong) as I upgraded the graphics card to an Air Cooled 1080ti, I decided to do away with the custom loop and go with an AIO for the CPU - the BeQuiet 240mm AIO loop.
CPU is a 4790k @4.6Ghz
Since installing the BeQuiet loop, on running Prime95 Blend test, it jumps from 30c idle to 65c, then within 7 minutes it is topping out at 100c, the fans are going full blast to no avail. If I run the main heat producing Prime test it jumps straight to 90, then hits 100c within a minute. Although doesn't appear to throttle itself or crash. Temps measured in RealTemp
Seems to hold at 60-70 in game, which is it's main use.
I have already re-seated it twice but no joy (using the paste provided), still doing the same thing, the pump is definitely working, although connected to a 12V rail from the PSU, not on a Mobo header.
Any ideas?
Any ideas?
