Hi,
Bequiet have had some great success with the release of the Silent loop range and after many customer were requesting that a 360mm model needs to be created they have decided to answer that request. The 360 completes the Silent loop range which includes the already available 120mm, 240mm and 280mm.
Check out the features and the Specification of the 360 Silent loop below.
be quiet! Silent Loop Superior Liquid CPU Cooler - 360mm @ £149.99 inc VAT https://www.overclockers.co.uk/be-quiet-silent-loop-superior-liquid-cpu-cooler-360mm-hs-01a-bq.html
Socket compatibility: Intel®: LGA 775 / 1150 / 1151 / 1155 / 1156 / 1366 / 2011(-3) Square ILM / 2066, AMD: AM4 / AM2(+) / AM3(+) / FM1 / FM2(+) , 3 Year Warranty
Silent Loop brings the famous be quiet! whisper-silent technology to the world of All-in-One water cooling. Designed to make installation simple, Silent Loop includes everything needed in one package.
Features:
- Innovative decoupled reverse-flow pump runs smoother, quieter and with less vibration than conventional pumps
- Full copper radiator for an impressive cooling performance
- Three Pure Wings 2 PWM fans provide quiet operation with high air pressure
- Customized fan speed thanks to PWM function
- Easy handling due to flexible bend-protection tubes and convenient mounting
- Full copper parts and a refill port extend the product’s life span
- Nickel-plated cold plate allows optimum use of heat-conducting metallic paste
- Compatible with Intel® and AMD™ sockets
- 3-year manufacturer’s warranty
- Product conception, design and quality control in Germany
Specification:
- Model: 360mm
- Dimensions radiator, incl. fan (H x W x D), (mm): 397 x 124 x 55
- Maximum power capacity (W TDP): 450
- Pump Type: Reverse Flow Pump
- Pump Speed: 2,200
- Pump Connector: 3 Pin
- Radiator Dimensions: 397 x 124 x 30
- Radiator Material / Finish: copper / black spray painted
- Base Material / Finish: copper / dark nickel plated
- Fan dimensions (mm) / Quantity (pcs.): 120 x 120 x 25 / 3
- Noise level (dB(A)) @ 25 % / 50% /100% rpm: 16.1 / 23.8 / 36.9
- Speed @ 100% PWM (rpm) : 2,000
- Airflow @ 12V (cfm / m3/h): 65.51 / 111.3
- Air pressure @ 12V (mm / H2O): 2.23
- Bearing type: Rifle
- Motor technology: 4-pole fan motor
- Connector: 4-pin PWM
- Lifespan (h / 25°C): 80,000
Only £149.99 inc VAT.
ORDER NOW
All Bequiet Silent loop coolers available here.
Features:
Specification:
- Model: 360mm
- Pump Speed: 2,200
ORDER NOW
