From time to time I get to build a silent PC. Always good fun! Now an important issue with a silent PC is drive noise, which can be greatly amplified by the case itself. My typical answer is to use isolation mounts, but times move on and that method is not really practical anymore. Not only are the mounts getting difficult to find, but many manufacturers are moving away from 5.25" bays.
I haven't used a bequiet Silent case before, so I am wondering ~ I know that the isolation on the "Base 600" doesn't work very well, but the Silent looks a lot better. The ant-vibration mounts look like they should be really effective. Has anyone used these with a fast mechanical drive? Are they good?
