BeQuiet Silent Wing Fans!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
The new range of BeQuiet Silent Wing fans will be arriving in the next few days.
BeQuiet SilentWing USC 140mm Fan @ £16.99 inc VAT
When developing the new generation of our housing-fan series SilentWingsUSC, two things were of particular importance to us: that they should run extremely quietly and at the same time achieve optimum airflow - an extremely tricky challenge.
And with the newly developed Ultra Silent Concept (USC), we have mastered this challenge. The USC comprises, amongst other things, two Innovations from be quiet! protected by german utility patent. In addition, the housing fan has a remarkable lifespan of almost 300,000 hours.
But, of course, our SilentWingsUSC exhibit other features, too. That's why the 120mm SilentWingsUSC came out on top in a comparative test by PCGH, and as a result was awarded top product - another result of our work into which our knowledge and, more importantly, our entire passion goes.
- Screwless anti-vibration fixtures and rubberised fan frame protected by german utility patent
- Quiet operation thanks to the reduction of vibrations and simple installation without tools
- Minimisation of electrical noises at a constantly high running smoothness
- Fan Speed: 1000 RPM
- Air Flow: 60.4 or 102.7 CFM
- Noise Levels: 16.5 dBA
- 3 Pin Molex
- 3 Year Warranty
Only £16.99 inc VAT.
ORDER NOW
BeQuiet SilentWing USC 120mm Fan @ £14.99 inc VAT
- Fan Speed: 1500 RPM
- Air Flow: 50.5 or 85.8 CFM
- Noise Levels: 17 dBA
- 3 Pin Molex
- 3 Year Warranty
Only £14.99 inc VAT.
ORDER NOW
BeQuiet SilentWing USC 92mm Fan @ £13.99 inc VAT
But, of course, our SilentWingsUSC exhibit other features, too. That's why the 92mm SilentWingsUSC came out on top in a comparative test by PCGH, and as a result was awarded top product - another result of our work into which our knowledge and, more importantly, our entire passion goes.
- Fan Speed: 1800 RPM
- Air Flow: 32.6 or 55.4 CFM
- Noise Levels: 16 dBA
- 3 Pin Molex
- 3 Year Warranty
Only £13.99 inc VAT.
ORDER NOW
BeQuiet SilentWing USC 80mm Fan @ £11.99 inc VAT
But, of course, our SilentWingsUSC exhibit other features, too. That's why the 80-mm SilentWingsUSC came out on top in a comparative test by PCGH, and as a result was awarded top product - another result of our work into which our knowledge and, more importantly, our entire passion goes.
- Fan Speed: 2000 RPM
- Air Flow: 26.0 or 44.20 CFM
- Noise Levels: 15 dBA
- 3 Pin Molex
- 3 Year Warranty
Only £11.99 inc VAT.
ORDER NOW
Cracking performance and quiet.
Shame about the looks - but that doesn't really matter!
they will be spinning at around 1000rpm so you wont see them.
fans are fans to me,if they are quite and move a good amount of air then its all good :D
are these better than apaches blacks? i ordered 2 apaches for my case but i might return under dsr if these are better, i need static pressure because i use dust filtering and noise up to 20dba ish.
*edit* i see the bequiet site has been updated with the specs and they are inferior to the apaches and the 140mm be quiet has not even 1mm static pressure compared to 2mm of the apaches 120mm.
so if anyones considering buying according to what i see the apaches still win.
