Best 120mm fan for a RAD
21 Mar 2005
Sunny Glasgow
Hi,
Does anyone know what the quietest 120mm fan for a RAD is? I’ve been recommended AeroCool Turbine Fans but I’ve also been looking at AcoustiFan: DustPROOF 120mm fan and S-FLEX 120mm Fan (800 RPM, SFF21D).
Cheers
Poggy
I hate it when I see this question!
The quietest fan is one which is not running.
Oh! You'd like it to cool as well!
OK, how cool do you want and how thick is the rad? How restrictive is the rad?
You see, when you take a "silent" 120mm fan, the chances are that it has no "pressure". Once directed at the slightest restriction all actual air movement ceases (to a greater or lesser extent).
Take either of the fans and look for the static pressure specification. Can't find one? Neither could I. So, at like 100rpm it achieves 44cfm blah blah in free air! Now try that through a radiator which unless you've got a Thermochill PA??? will effectively stop almost all actual air flow.
Hmm. Wonder how much cooling the fans will achieve?
Now go look for info on the Panaflo L1A.
Very first link Google gave me led me to a US store who quoted: "Max. air pressure: 3.3 mmH2O"
Not actually sure what that means but that's not my point. At least you have a complete set of stats.
Bottom line is that - when all my ranting is said and done - the 38mm deep Panaflo L1A is capable of still pushing air through a radiator while running silently at 7v.
maybe i should have said that too.
Save you ranting again Mike :)
I feel the same when i see people put " i want DDr600 ram cos mine is holding my overclock back"
when in reality running 1:1 may well hold it back even more.
Tom
:eek: Now now children i only asked a question, play nice please :p
Thanks for the replies though guys especially yours Mike, very informative :D
Either the Panaflo's mentioned or Papst FGL-Series (4412F/2GL). The Papst's push plenty of air through my 240 rad which is about this thick ... *holds finger and thumb slightly apart* :D
