Best 120mm fans for radiators
They are at least on par, if you already have typhoons then probably not worth a sidegrade, but if looking for something similar to typhoons and cant get hold of them then these are fine
Well actually no, since the stock fans there are much higher max speeds than these. But also way louder. If you compare rpm to rpm, then these OcUK Silverstone fans will be better so it's depending on how loud a person can handle.
