Best 140mm Fan?
11 Aug 2008
Hey.
I've got a fractal design define r4 case and I'm looking at replacing the the front fan & adding another.
Whats the best quiet 3 pin fan to use for the front of the case? (it does have the hard drive cages in)
I got both AF140 and Noiseblocker blacksilent pro PK2 140mm for different PCs. The AF series are not good, trust me. the Noiseblocker ones are clearly better.
Hi, l'm using 140mm Zaward 900rpm fans set to pull on a 560 GT Stealth Rad cooling a i7 920:4.2ghs/toxic@6970 at 22'c ambient room temp cpu core's are 52'c to 55'c/gpu 47'c playing blops 11 for just over 2 hours they are very quiet indeed not bad for £8 each, they do make upto 2000rpm which you could use a fan controller for case use..
the be quiet silent wings 2 are by far the best 140mm fans in terms of noise levels. I have 3 of them.. really expensive but they are on another level to all other fans (in terms of noise!)
not 100 percent sure if they fit in the front of the r4
