Caporegime
- 21 Jun 2006
what is the best 19 inch widescreen tft? also value for money i have up to say £150 to spend
just remember a 19" widesceen tft is only 1 inch higher in screen area than a 15" 4:3 lcd. if you can handle that then its fine
it really isnt a case of 'ooooh its so much bigger' though. please go and look at one before dropping money on one
james.miller said:ok thenjust remember a 19" widesceen tft is only 1 inch higher in screen area than a 15" 4:3 lcd. if you can handle that then its fine
Hxc said:You have 4" larger diagonal, yet only get 1" bigger?
http://img340.imageshack.us/img340/6985/size21vu.png and http://tvcalculator.com/index.html?21984f7af292614c98af5b3a989d7f35
Seem to suggest its a little bit more than that mate.
if that doesnt convince you nothing will, but at least go and see one in action first. there's no reason not to.james.miller said:no, it isnt. infact its almost exactly 1.06" higher and 4.12" wider than a 15" 4:3, or 1.8" shorter and 1.27" wider than a 19" 5:4.
www.tvcalulator.com is a wonderful resource, but why are you looking at a 20.1" and a 17" there? we're talking about 19" widesceensif that doesnt convince you nothing will, but at least go and see one in action first. there's no reason not to.
http://tvcalculator.com/index.html?d8bb0f1f098162a2e6e163b399923517
will give you the real screen sizes. a 17" 5:4 is half an inch taller by the way.
i like it when you throw my sony 40w in to the mix http://tvcalculator.com/index.html?dcf0dc74d3454cc9faf3f4c836895533 hehe
