get some t20's, they may be 2.0 but in the price bracket i doubt most would be able to tell.
if you feel the need for a sub and cannot live without you need to spend £100ish tbh, otherwise you end up with a cheap sub in which the bass travels everywhere around the house, and is not focused the room your in.
bass will go wherever it wants. it'll happen with a £20 bargain bin subwoofer, and it'll happen with a pc13ultra. the key is the placement of the subwoofer
