Best >£20 AM3 Cooler?
21 Jan 2010
Ceredigion
Hi,
As per title really, decided to go for an Athlon II X3 instead of the Phenom II X2 giving me approx £20 to spend on a decent cooler, and £5 on the best TIM (is this still AS-5?) to get the best overclock I can!
Thanks,
Alistair
Just use the thermal compound that comes with the cooler, oftentimes it will be better or you won't notice a difference from AS5 (actually, MX-3 is supposed to be the leader now).
Anything from a Coolermaster Hyper TX3 to an Arctic Cooling Freezer 7 Pro rev 2 or any other number of coolers depending on what you want. Low temps? Low noise?
Used the Arctic 7 in the past on systems and not had any complaints also this comes with MX-3 pre applied.
With RE to Superewza, Im not too bothered about noise, either have music blasting through speakers or headphone/set on!
More bothered about price/performance aspect and how well it will cool a chip under high load.
The CM Hyper 212 seems to come out reasonably well in reviews, but cant find any figures on it :confused:
