I don't know where to begin, I have had the worst few days ever.
Basically Ive been using a BenQ XL2411Z 24 inch 144hz monitor for over 6 years. However recently I managed to get a new RTX GPU which made me want to buy a 1440p display since I have the hardware for it. I went ahead and spent a few days doing mass research and comparing monitors and I ended up buying the Dell S2721DGFA which arrived two days ago. Ever since I plugged it in I can only find things to complain about, it's actually upsetting me because I was looking forward to upgrading to a 27" 1440p display but it seems like the colours are really OFF. For example the reds on my display look extremely neon bright yet everything else looks washed out and faded. The blacks are grey and don't look black at all.
I've downloaded the driver and used multiple ICC profiles along with checking if I have the native resolution selected but nothing has helped me. I did some research and it's either a faulty panel or I'm not used to it. But the reds are so bright compared to over colours it doesn't look right whatseover.
So I'm in the process of wanting to return the monitor and I will go back to what I know I was comfortable with. A 1920x1080 24" display. However I will get a 240hz one, will this display have sharp and crisp colours like a 1440p monitor would? I'm so confused and upset to know what to do right now.
Is it possible for someone not to like a 1440p 27" Also when I watch Twitch streams the gameplay looks so blurry on my 1440p display. why? What is causing this?
