Best 27/28 inch thin bezel 4K monitors
4 Nov 2006
London
So I'm currently rocking 2 x U2515H's from Dell which are great. But I originally wanted to have 27 or 28" ones so I could play and watch TV from my bed.
Been on the lookout for a 4K pair now and the one thing I really want to keep is the thin bezels. I would have gone for the U2715H's but its exactly the same as the U2515H but in a 27" format.
I've seen the LG 27UD58 series but that has thicker bezels, so it looks like the 27UD68 or 27UD88 are what matches my criteria.
Are there any others out there that I'm missing? Do Dell make a 27" 4K InfinityEdge monitor?
Any suggestions are welcome.
Cheers
There's a Dell 27" 4k InfinityEdge on the way, the U2718Q. According to the press release it's due for a mid-July release in the US for $699.99. It'll probably be £700 on this side of the pond, but with any luck Dell will offer a discount as they often do. I'd quite like to get a couple of them to replace my pair of aging U3011 monitors, but I'm not keen on paying £1400 for the privilege...
Ooh so you're right! Yeah I would want to get 2, but not at £1400. THe LG's might be my only other option seeing as they're only £400 each (UD68). Plus I might find the new style of the menu joystick underneath easier to use than on screen buttons to manage the settings. Whilst it doesn't have the nice stand that the Dell will inevitably come with, I'm using a dual monitor stand so they'll be in the box anyway!
I will keep an eye out for those and hold off on purchasing for now.
If you are looking for slim bezel go for the 28UD88 - it has the infinity display which is the super slim bezel
Does the 27UD68 not have a slim bezel too? I thought the 58 was the normal bezel, and 68 and 88 models have the slim bezel. It's a bit confusing as some retailers show the UD68 picture on a UD58 product page.
