Best 27" monitors for 3d Eyefinity? Thanks
20 Jun 2009
UK
Hi
can anyone say if any of the current 27" 3d monitors are good for 3d in Eyefinity, I'm in the love with the Samsung 750d but it don't have a rear wall mount from what I can tell, also will it be a problem with the anti glare screen in Eyefinity. Thanks!
Aren't you going to need 3 monitors with DisplayPort connections or if the monitors have dual link DVI-D connections you'll need 2 expensive DisplayPort to dual link DVI adapters?
