- 4 May 2006
What 2gb kits in this price range overclock/perform the best?
Minstadave said:The Gskill ZX is very nice as is the OCZ CAS2, you could go for PC4000 though, but if you're on A64 it doesn't make a lot of difference.
Richdog said:G.Skill 2GB DDR2 HZ PC2-6400 (2x1GB) CAS4 Dual Channel Kit http://www.overclockers.co.uk/acatalog/GSkill_Memory.html
Those are two good kits available here, the Gskill a bit over budget though.![]()
Devious said:or Team Group 667 C3's , around £135
