best 2gb kit for abit nf7s v2?
16 Sep 2003
House
time to upgrade, so whats the best/stable for running at 200mhz 2,2,2,11 or 2,3,3,11? these have caught my eye so far,
OCZ 2GB (2 x 1GB) PC3200 Dual Channel Platinum Series EL-DDR CAS2 (OCZ4002048ELDCPE-K) (MY-057-OC)
Corsair 2GB DDR XMS3200C2PT TwinX (2x1GB) CAS2 (MY-079-CS)
Corsair 2GB DDR XMS3500LL TwinX (2x1GB) CAS2 (MY-107-CS)
G.Skill 2GB DDR ZX PC3200 (2x1GB) CAS2 Dual Channel Kit (F1-3200PHU2-2GBZX) (MY-007-GS) - had a gig of ZX last year and failed memtest with hundreds of errors, didnt like my mobo i think.
so what to go for? cheers :)
My ocz el ddr doesnt clock particularly well. Bit dissapointing tbh.
if i could choose again id prolly go for the corsair 3500.
But as u want too run stock the ocz is very stable at spd settings
just tested this ocz el ddr v2 2gb kit out and i'm very dissapointed :( plugged it in and went into bios and notice it's spd is 2.5,3,2,5 not cas2 then hmmm. so i try it at 2,3,2,5 with the recommened voltage - 2.8v and memtest failed to load, turned it down to cas2.5 grrrr and test 5 failed with 27k errors, 2.5,3,3,5 fail, 2.5,4,4,5 fail, 4,4,11 fail cas3,3,3,11 pass woooo
it was so hot i could barely hold it to remove it, is that normal?
so i've got 2gig of cas3 when i ordered cas2, rma time i think.
