- 29 Aug 2010
- Cornwall
Hi all,
You may be aware that I'm having issues achieving the temperatures and quietness that I hear so much about. There is the option of getting 1 or 2 1080 rads and getting a case/stand for it (or them), but this seems a bit drastic. Also, I'd like it all to be contained within the PC case if I can.
I'm currently using a CM 690 II advanced with:
Top: XSPC RS240 rad (240mm)
Bottom: EK Coolstream XT 240 (240mm)
I'm currently using Apache Vipers on them but have got some 1850rpm Gentle Typhoons that I've not yet gotten around to fitting.
I'm wondering if I'd be better off buying a case that would support a thick 360mm rad?
I know I'd effectively be going from 4 x 120mm of rad space to 3 x 120mm of rad space, but if I got a thicker rad (e.g. Black Ice GTX or SR-1, Phobya G-Changer, XSPC RX360 or a Thermochill TA) would that more than make up for it?
Which of the 360 rads available these days is the best?
Does a thicker rad mean you need higher rpm fans or will it cause more noise?
Is it better to have a higher or lower fin density? (Black Ice SR-1 had 9 fins per inch, while the GTX has 20 fpi)
Thanks.
Thanks.
