Best 3770k batches for 4.8Ghz+ 24/7 clocks
Permabanned
15 Dec 2008
What batches should I look out for 8Pack?
I have the cooling to handle and want as close to 5Ghz as possible if not dead on 5Ghz.
Just got my new Gigabyte Z77X-UP7 board so should have no issues taking a chip up that high.
Week 18 and 29 Costa where best ever batches. After that I am not sure. I still have some of these so have not needed to test in ages.
That is a damn good board, i was going to get one, but in the end i decided it was too expensive and went for the mpower. I hope you manage to find a good chip to go in that badass board.:D
what cooling do you have? you'll need a pretty golden chip to do 5ghz 24/7 imo
4.8ghz would be more realistic with a delid and a decent chip
its just the luck of the silicon lottery,unless you work for intel
as for the board youll have no problems going 5ghz+ just comes down to the cpu regarding voltages and cooling ect
how come you upgraded from a 2600k @ 4.8ghz?
yh but its getting them,only way is to try your luck from shops or scouring online auctions
I forget the batch of mine off hand but im at 4.8ghz with 1.38v on air
Out of interest 8pack, what was your best 3770k regarding less v when it came to 5Ghz, if you did ever test that.
I've got my 3770k running 4.4 @1.130/5v and with not much testing got it running 4.5 @1.175 (I haven't tried to see if it runs lower at 4.5)
I'm thinking of upgrading my cooling just to see If I can hit the Magic 5GHz, it won't be a 24/7 thing, just to see if it will achieve it then back down to 4.5 :D
delidded? that's good if non delid,most for me is 1.38v and 72-75c any lower voltage I get whea errors/warnings,using offset voltage
Got a chip that Cosya Rica week 37
Can't find any OC results, even trailing through HWBot serial and batch number thread turns up nothing.
You know anything of this batch 8pack?
3337B628
