Noctua NF-A4x20 with the low noise adapter?
This is the 12v PWM, there is also a 5v version and a 3-pin version:
https://www.overclockers.co.uk/noctua-nf-a4x20-pwm-5000rpm-fan-40mm-fg-05v-nc.html
Can't say what the noise is actually like as mine aren't installed in a quiet area.
@ OP what is it for?
I bought a little 80mm (PWM/USB) in a kind of mount/stand for my VM HUB4 the other day as running hot.
Depends how much airflow you need, but the Noiseblocker 40mms are good value if your airflow requirements are more modest:
The XM1 is rated at 4.9 m³ / 9dBA - £4.49
The XM2 is rated at 6.7 m³ / 14dBA - £4.49 (Similar airflow to Noctua NF-A4x10 FLX when using LNA, for 1/3 cost)
Above that the 20mm deep Noctua makes more sense
Noctua NF-A4x20 PWM at 9.4 m³ / 14.9 dBA - £13.99
https://www.blacknoise.com/site/en/...-fans/nb-blacksilentfan-series/40x40x10mm.php
My basket at Overclockers UK:
- 1 x Noiseblocker BlackSilent Fan XM1 Fan - 40mm (2800rpm)= £4.49
- 1 x Noiseblocker BlackSilent Fan XM2 Fan - 40mm (3800rpm)= £4.49
- 1 x Noctua NF-A4x20 PWM 5000RPM Fan - 40mm= £13.99
