Best £50ish noise cancelling earbuds
1 Jul 2007
Various
I'm after some noise cancelling earbuds for around £50. They'll be used for my usual winter commute into work (i.e. on the tube, when my usual running earbuds won't cut it). I've already got some Bose over-ears for longer journeys and flights, so don't need anything super high end. I just want something with sufficient noise cancelling for me to be able to hear it, and also to be easily pocketable (which is why I don't use the Bose ones for commuting).
I've had two Anker / Soundcore sets previously, and the right earbud on both has stopped charging after a while, so Anker are a no-go for this.
Thanks!
