best 5in1 hdmi splitter
1 Jun 2017
hi
out of these 2 5in1 hdmi splitters what would be the better overall switcher to use
E-SDS UHD 4K@60Hz HDMI Switch ,5x1 HDMI Switch vs xolorspace smartooo 23051 @60hz
need it for the best audio and resolution for 65e6v oled tv
with sky q box virginmedia v6 box buzzbox xls 3000 android box
ps4 pro
xbox one x console
nvidia shield console
sony ux800 4k player
pc
wii u
which one has the best update specs thanks
do you mean switcher or a sp
hi
do you want splitters or a switcher?
i assume is to connect 9 devices one tv so it would a switcher
but if it not, and you mean to connect to all your devices to two tvs you would be better off using a hdmi matrix which would allow two different outputs at the same time and as a bonus you would be able to extract the audio so you can pair it with an av receiver for better sound that your tvs speakers
on a separate note, some av receivers are able to function as an hdmi matrix/hdmi switcher but it could get very expensive quickly if you want 10inputs
sorry if i am not able to help choosing between those two hdmi switches but i cannot see a difference between the two
These are your typical Chinese import switches. The description reads like a poor attempt at search engine optimisation i.e. throw in every key word possible.
There are vague descriptions of what they claim the switches will do, but it would be overstating things to say there's a specification.
Perhaps go on the customer reviews?
You want a HDMI switch not a splitter. These are expensive, it'll be better to buy a AV amplifier with HDMI inputs you need, and get a proper sound system to boot.
I use a Octava switch, I think they were about £150. It's old HDMI spec now, not 4K but probably similar price to new models of it.
