Hello.
I'm looking for a solid 802.11n router to replace my aging DG834G v3.
But unfortunately I always find routers to be overlooked by most tech sites, and you can never really find any decent reviews, and I find that any reviews you do come across are just fluff (i.e. no benchmarking)
The main priority is throughput, as the DG834G doesn't really cope when streaming 1080p content, it just about manages on more sensible 720p stuff, but I would like to be able to wirelessly stream (to a wired client) most of my HD content, and I think a decent 802.11n router would be satisfactory.
I could use my DG834G as the modem for a standalone router, but I'd prefer not to, unless it's something exceptional.
Something that can cope with a high number of connections when torrenting, etc, would be nice as well, as my DG834G can get a bit overwhelmed in those situations.
I don't think anything with 9000 aerials or dual band is really necessary, as my DG834G delivers enough range, and 2.4ghz isn't that congested here. (A couple of routers with 2% signal or however you want to put it), but these features may be par for the course anyway.
From my findings, the Linksys E3000 seems to trump all the competition by a huge margin in this bracket, but if there are any hidden gems, I'm sure you guys will suggest them, so I thought I'd make a thread just to see
Cheers.
Cheers.
), even at the £100-150 level, most falling considerably short of the throughput of the E3000, more than 50% slower sometimes, and that's on the same band and standard :/
