Best 775 air cooler?
4 May 2006
What would be the best air cooler to use in an aspire x-qpack, i've heard conflicting reports on both the blue orb and the zalman cnps7700 being the best. Also does the cnps7700 really fitusing the motherboard tray.?
The Golden Orb definitely fits. I can't see any reason why the Blue Orb shouldn't fit, and the 92/120mm Zalmans are almost exactly the same dimensions.
My current favourite tight space cooler is the mCubed Borg as you can angle the heatpipes to suit yourself and it fits pretty much anything.
another vote for the freezer 7 pro, you simply cant go wrong for the money
search the forum for freezer and you will find tons of posts praising it
