I've also recently been looking for a new 10G capable sw. itch, but with 10 ports instead of 8.
The Zyxel XGS1250-12 seemed to be good value to me for the number of 1G ports and 3x 10Gbe connections and 1x 10G SPF+ connection for about £240. It doesn't do PoE however but if you only needed one port you could use a PoE injector which are widely available for not much money. If you can live without the management functions, then the XGS1010-12 is available for about £120.
I was looking for a switch which allowed both port security (restricting a port to a specific MAC address), and time based access to effectively disable some ports at specific times of the day, and the 1250-12 doesn't have this level of configurability. I'd need to use their XS1930-10 instead which does have these functions. However it's about twice the price as all ports are 10G capable which puts it on a par pricewise with some Netgear 10G switches, and it's a bit more than I was willing to pay.
I'm currently trawling through the Netgear, Microtik and QNAP options to find the best solution and value for money.
