Best 8800 drivers for XP?
24 Sep 2005
Stoke
Just picked up one of these and it should be getting delivered tomorrow. Are the latest WHQL drivers good and with minimal buggyness? Or should i be looking at some betas?
SOLDNER-MOFO64 said:
The latest WHQL's are going down very well. No problems for me.
If you're a bencher you may wanna grab yourself 97.92 WHQL from www.guru3d.com in the FORCEWARE section, huge FPS increase if you're running XP.
Are these faster than the 158.22 or the beta 162.18 drivers?
Arn't 97.92 really old? I remember using them when I first got my 8800GTX.
Im using 162.18 right now and having no problems at all, Best ones yet I think.
Latest WHQL'd drivers are the 158.27's which you can get from Guru3D, just the same as the .22's, but have newer fix's being a newer set, so either of those 2x would do, but like above im now on the 162.18 beta's now which are also working great.
