Best 8800 GTX aftermarket air cooler?
Ah, there must be a mistake on OcUK's info listing for the Thermalright HR-03-PLUS (8800 GTX) VGA Cooler. It says it has 4 innovative designed heat pipes.
This aint true, the Thermalright HR-03-PLUS (8800 GTX) VGA Cooler should have 6 innovative designed heat pipes.
Whats the story?
Mud said:
Is there a solution that will fit a DS3P with NH-U12F and with PCI cards installed? That's my holy grail.
Got my GTX fitted with a HR-03 Plus on a P35 DS3P.
The cpu cooler is a Ultra 120 Extreme and i have a soundblaster live! 24 in the uppermost PCI slot.
You could get another small pci card in just but you might have to use a thinner fan on the cooler to guarantee some kind of airflow.
gt
gt
Looks good! whats the best fan to use with these then? i was hoping to use a Panaflo H1A 92mm with it but OcUK don't seem to stock em anymore. I do have the old spec Panaflo 1A 92mm which i salvaged from my old blown power supply. i'm toying with the idea of just using this but i'm not sure as it only has + & - wires.
Did you get your Thermalright HR-03-PLUS (8800 GTX) VGA Cooler from here? Obviously if you did then it deffo is a typo in the description. What if anything are you using to control the fan speed?
I did get mine from OCUK so can confirm that it is a typo. The Plus is a very different beast made purely for the demands of 8800 cards.
The pack comes with all the heatsinks you'll need, the clips for attatching a 92mm fan, decent install instructions and finally a large syringe full of thermal paste.
As for the fan i use a Xilence Redwing. Not the most airflow in the world but very very quiet. It's more than adequate as the cooler is so good.
I have the card clocked from 575/1000 to 645/1025 and under full load it stays at around 60c. With the original cooler on i saw temps tip over 80c at stock!
gt
Thanks gt_junkie, but I'm afraid I use an x-fi and a dvb-t card, making things that little bit too tight it seems.
I've just added a 120mm fan loose in the case, that's dropped idle temps from 80->70'C...I may be able to progress without spending money and invalidating my warranty :D
edit: further tweakage has got me down to 55'C :eek:
Okeys just bought one of these Thermalright HR-03-PLUS (8800 GTX) + a 92mm Xilence Redwing fan for £49.97 inc p&p
Read loads of reviews on both items. Both spot on..
I have some AS5 here, am i better off using that for the core?
Nice one!
Believe me... you won't be dissappointed! ;)
As for the compound i would say use either. My temps are good TBH and i have heard a lot of reviews to back up my belief that the stock thermalright paste is more than acceptable. It's also super easy to spread too!
Enjoy it mate! :)
gt
Yep you won't be dissappointed with this beast,
My temps went from:
68 idle to 53 Idle
80 Load to 61 Load.
Very good and I used Zalman Super Grease. Really easy to apply, you just have to paint it on.
AS5 should be do a fine job though.
