Best 8Gb memory on OC?
6 Aug 2009
I am so confused, I wish you could filter by reviews/rating (highest first) on the shop.
I have seen the teamgroup vulcan red with 9-9-9-24, then i also see other modules are 7-7-7-21 does that mean these are faster? There is also 9-11-9-24, guessing these are slower than 9-9-9-24.
I want to best 8Gb Ram for around the £60 mark, my mobo can accept max 1800Mhz o.c. so a set of modules that are good for o.c. would be great.
Guessing it is better to buy 1866+ memory to o.c. to 1800mhz or is that wrong?
As many suggestions as you can give would be appreciated and reasons behind.
Thanks,
I should mention my build is;
Phenom II x6 1100T
ASUS M4A78LTM
2GB GT610
300w PSU (Upgrading to superFlower 400/450 soon)
WD Caviar Green 500GB 7200RPM
Thanks,
If you want to OC then aim for a high speed set. The timings are important for performance but you want high speed tight timings. If you search you will see some comparisons on speed vs timings.
